跳转到主内容
Teardown information for the Nespresso CitiZ coffee machine. They are available from different brands, e.g. Krups, DeLonghi.
How to actually disassemble the model pictured (silver)?
The one pictured for the article is the model that silver with panels that wrap around the front. The ones in your teardown aren't the same. I can't use the same method to pry off the panels. I'm stuck.
Update (03/28/24)
Delonghi EN167C
I eventually found a guy on YouTube that does it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Both models disassemble basically in the same way.
With the depicted model (where the buttons are towards the front), you have to first remove the design cover of the coffee outlet at the front, before the side panels can be removed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rywm1978 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 190
