跳转到主内容
加入维修社区 - 创建账户
Grand Prix 在 2004 年进行了更新,采用了 GM W 平台的改进版本,并于 2002 年 2 月 7 日在芝加哥国际车展上作为 Grand Prix G-Force Concept 概念车首次亮相。
Anti theft system/Lock system, stuck in learning mode
So I got an 05 grand prix, the theft system is in learning mode and I can start it, though I only have the valet key for it, I assume if.i just do the learning procedure it will take it out of learning mode though, I haven't tried it cause I'm not sure if my key will start it if I do and I'm not ready to pay for that headache , unless itl be fine if I do take.it out of learning mode, also having issues with the door lock switches only locking the doors and the trunk release won't work either cause it's part of the lock switch, but putting it into drive locks and putting it into park unlocks them just fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If you do take it out of learning mode and your keys can’t start it use this method
*****THIS IS A COPY*****
Put the key in the ignition and attempt to start the car, the "Security" light should go on and the car won't crank. Don't move the key to the "off", leave it on.
  1. Leave the key in the on position for around 10 minutes, the security light should eventually go out.
  2. Turn the key to "off", wait 5 seconds, then attempt to start the car. If it starts, you're done! If it doesn't start, to back to step 1 and try again. You may need to repeat this process up to 3 more times to get the car started.
这个答案有帮助吗?
得分 0
3条评论:
I don't know how to get it out of learning mode though.
完成的
The security light never goes out I waited for a full 30mins even
完成的
@jameswiencek I don’t know then I’m sorry
完成的
添加一条评论
添加你的答案
James Wiencek 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 986
