跳转到主内容
Black screen on display and external monitor
I have change the motherboard, battery works, it chimes at start but only gives black screen in the internal display and external monitor, is the motherboard faulty or is something else ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
What did the original logic board show you? I would double check to see if that is also failing in the same way. Maybe you have a different problem.
Are you sure the external display connection is good? If that’s the case then it’s likely you have a bad logic board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mitigations 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 98
