跳转到主内容
2022 Hybrid Blue USB port replacement
Bought a used 2022 Hyundai Tucson Hybrid Blue but the data USB port is damaged like in the picture below and the dealership won't do anything about it, OEM parts online are only about $30 wondering if there is a way to safely remove the trim to get access to the internals to swap it out
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Found the official instructions online, but I can't upload them, unfortunately. Hope this helps!
  1. Disconnect the negative (-) battery terminal.
  2. Using a flat-head screwdriver, remove the floor console tray assembly (A).
  1. Remove the USB (A) by pushing hooks in the direction of the arrow as illustration below.
  1. Remove the audio unit.
  2. Remove the USB after disconnect the USB connector (A).
这个答案有帮助吗?
得分 1
2条评论:
do you mind sharing where did you get the instructions online please.
完成的
Chilton's manuals. You may be able to access it through your local library.
完成的
添加一条评论
@wicked62123 I’m having the same issue. Were you able to fix it yourself?
@cvneutron - can you provide the website to where you found the instructions?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
wicked62123 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 97
总计 1,276
