跳转到主内容
加入维修社区 - 创建账户
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
Boot Chime - Screen Flashes on - Then nothing...
So today I changed the display cable as the hinge was broken on the old one, I took hours and extreme care and followed the guide exactly as it isn't the easiest of jobs, connected everything back up and on the 1st restart I got a chime and a white screen which went brighter as if the OS was loaded but there was only a white screen.... so I checked everything over and everything appears fine, all neatly back together as if there was no repair.... I carefully connected the display cable to the logic board again, booted up again and to my horror it chimes and the screen flashes on, then goes black and nothing is happening internally or externally..... I even put back the old cable and the same is happening, so I changed back to the new cable and hinge.... I guess I have I screwed it up completely or is there a known reason why this is happening? I searched the net for solutions and similar issues, all I found was to reset SMC and PRAM.... which has made no difference. Baffled.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Fan is spinning...... but as soon as the screen turns on (Then immediately goes off) nothing else is happening..... I guess something has blown up on me.... what is the name of the part where the display cable connects to on the screen? A thin black plastic piece that has 2 connections on it, maybe I hurt the backlight cable part? Need to know the name of this part so I can search it.....There is no clear guide that II could find that shows how to deal with it.... only when the whole glass is out.... Flexgate if thet what it is called although it is a fixed part looks intact no visible damage, looks fine, everything intact.
完成的
添加一条评论
1个答案
已选择的解决方案
@livfe - It is good to see you again!
Unfortunately what has happened here is fatal. Your Logic Board more than likely got fried by static. You will need to replace the logic board.
But, if you want to confirm (and I would recommend this), connect the Mac to an external display, shut down the Mac, and restart it with the lid closed. Wait for the Mac to boot. If it can boot on the external display, then it is going to be hard to determine if the Logic Board is broken, or the display itself. Really, the only way to test it is to get a new logic board, and see if the problem persist. So, I would recommend getting a replacement on eBay with a returns available. So, if the new logic board does not improve the situation, you can return it.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
livfe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 155
