跳转到主内容
发布于2011年7月21日。Core i5或Core i7处理器。雷电(Thunderbolt)接口。本机也用于Mac mini Server配置。
How to install OS on a newly added SSD?
Please provide details on how to install / copy lion os from the original hdd from a mac mini summer 2011 to the newly added ssd using the iFixIt hack.
I used Time Machine to backup everything on to the ssd. Is this a good thing to do? How do I safely boot from this hdd?
[I have no idea what will happen if I try to boot from this ssd, namely the Time Machine copy]
What is a good way to go about configuring the freshly added ssd to run OS on my 2011 mac mini? Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Hm, I don't know If you can boot from a timemachine backup, but I doubt it..
What I've done is simply clone from HDD to SSD with carbon copy cloner and changed the boot drive to the SSD, on the next startup your mac will boot from the SSD
这个答案有帮助吗?
得分 1
1条评论:
Thank you for answering so fast.
Carbon Copy Cloner did the trick for me.
It did take some searching for details on how to install and use the software but after copying everything I am now running Mac OS 10.7.3 on my newly bought 2011 Mac Mini, using a SATA 3, 60Gb SSD mounted as secondary drive.
I've also upgraded the memory from 2Gb to 8Gb. Also kept the original [and slow] 500Gb hdd for storage.
I am about to do some speed tests right now.
完成的
添加一条评论
添加你的答案
mirceachira 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,067
