跳转到主内容
A digital TV converter box by Apex Digital.
Weird thing happening with my converter box.
Hello,
I recently dug out my Apex converter box so I could watch TV from my Toshiba CRT television. I plugged it in, and pressed the power button, and it flashed red. Nothing showed up on screen. I held the button, and it continued flashing. That happened for a bit, until it turned green. The remote did the same. I saw a few white lines on-screen, and then nothing. I also heard some buzzing sounds when I pressed the button. I unplugged it and the high-pitched noise faded out along with the red light. The issue's very hard to describe in words. Is there any way to fix this, or is my converter broken?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @lappy48614311,
High pitched whine and noises could indicate problems with the power supply board in the converter
Disconnect the power to the converter box and open it up and check the condition of the capacitors on the power board to make sure that they're not leaky etc
Post some close up images of the board in your question 在已经存在的问题里加入图片
完成的
@jayeff LOL, with the final answer being posted below, it appears you called it! Blown capacitor indeed.
完成的
添加一条评论
1个答案
已选择的解决方案
Update: I recently opened it up and found that a capacitor decided to explode. I am terrible at soldering and do not want to risk hurting myself again, but I concluded that the unit had been damaged beyond repair. Luckily, I was able to purchase another converter from Apex and I was able to get television on my CRT!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lappy4861 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 186
