跳转到主内容
Ground Hog Augers (model HD99-H) are towable hydraulic augers with variable forward speed and reverse auger rotation. The HD99-H model can dig holes with any auger with up to 18-inch diameter.
1 个问题 查看全部
Where can I find the proper bit
We have the HD-99 not the HD-99H and when we order the bits from Ground Hog they send us a bit that is too shallow and will not fit. The current bit is a SB-25 with the number 1986 stamped above. The Drill itself has 12-C5 stamped on the bottom of the drill. There is a decal that has DC-DARA on the shaft of the drill. Can anyone help me with getting this bit as we have none of the bits working that came with the unit. Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Hi @jobewood
Can't find the bits as per the info you posted but if you don't get a better answer perhaps try using a suitably sized hub adapter to get the bits you already have working.
If there is a suitable size adapter listed for the auger and the bits sizes, search online for Pengo (insert part number (pn) of adapter) to find suppliers that suit you best.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jobe Wood 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 83
