跳转到主内容
The Samsung Galaxy A53 5G Is a Mid-Tier phone released by Samsung on March 17, 2021
22 个问题 查看全部
A53 slow down/lag/freeze after display replacement
Greetings ,
Yesterday i replaced a cracked screen for my customer's A53 that was not working since November of 2023 .
I found an OEM OLED Screen so i bought it replaced the old one .
After the repair was complete I turned the device on and ran the diagnostics where it passed all of them successfully, so I proceeded with gluing the back of the phone. I realized that the device lags quite a bit, so I suggested my client to proceed with factory settings because his mobile phone may have unwanted applications that make it slow. He took the device and proceeded to update the software and applications and noticed that the touch sometimes gets stuck, like when you try to browse your mobile phone with wet hands, something that is fixed by restarting the mobile phone, but it reappears after a while. It doesn't seem reasonable to me that the mobile phone is slow after a screen replacement, rather I believe that the mainboard flex is faulty and needs to be replaced. What is your opinion and what steps would you take in my position?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi @unscrewguru67,
Does it do this in safe mode?
Does it do this with the charger connected?
if yes and yes, you may have to temporarily replace the display just to know whether it is the display or something else.
Just verifying that the part number of the replacement display is GH82-28025A (or B, or C, or D)?
Just what I'd try.
Update (03/10/24)
@unscrewguru67
Here's a link to the service manual that may help if it isn't the display but something else.
It's a .rar type file so once downloaded, you will need to use something like 7-Zip to compile it so that you can read it
这个答案有帮助吗?
得分 2
4条评论:
Thanks for the quick reply .
It's something I haven't tried yet.
He will return the smartphone to me and I will try it.
In the case that it works properly with the charging cable or in safe mode, do we think that in the first case it is a battery problem and in the second case it is a software issue?
Thanks in advance
完成的
@unscrewguru67
Yes and that's what I would eliminate first.
I was updating my answer when you posted so check what I suggested about the part number for the display.
It is not unknown to sometimes get either a faulty "new" display (even OEM) or even to get the wrong one
Cheers
完成的
@jayeff
Thank you for everything ! I'll come back with an update
完成的
Sorry for the delay .
So i went to Samsung and we did replace the screen . That was the issue.
The previous LCD was OEM with 60hz screen and big bezels .
That was a big lesson .
I'll never buy again a low quality lcd for my customers
完成的
添加一条评论
添加你的答案
Unscrew Guru 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 17
总计 68
