跳转到主内容
Hyundai's entry-level vehicle. It's available only as a sedan; the hatchback was discontinued after the 2017 model year.
P0730 Gear ratio incorrect (pulley)
Hi I have a Hyundai accent to this is your card
front of me it's P0730 in gear my gear type is CVT and I don't know how can I fix it if anyone know I'll come and fix it say please do I answer this question
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
A logged P0730 code is a trouble code that indicates the transmission is slipping. The powertrain control module registers this code when there's a greater RPM difference between the rotational speed of the input RPM and the transmission output of the RPM sensor.
I would test the speed sensor and check the transmission fluid level first and foremost. This is an indicator of a failing transmission.
Cheers
Monte
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
AL MONSTER 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 10
过去 30 天: 28
总计 1,171
