跳转到主内容
发布于 2009-2012 年,带 13寸显示屏的 MacBook Pro (一体成型机身款)机型。
4630 个问题 查看全部
Making a multi boot installer SSD with OLD Mac O/S
I am using a MBP 11.5 15" Mid 2015 Retina with Monterey 12.7.3.
which also has a Windows 11 Bootcamp partition.
My plan is to make a multi-installer external SSD.
I have the following old installers that I wish to make into bootable installers:
OSX 10.4 Tiger DVD.iso
OSX 10.5 Leopard DVD.iso
OSX 10.6 Snow Leopard.dmg
OSX 10.7 Lion DVD.dmg
OSX 10.8 Mountain Lion.dmg
I have managed to get all the later OS releases in my applications folder as .app installers so those should be easy to create installers from terminal commands....
Can anyone assist in the operations required to get these onto an external SSD for installation use on older Macbooks. I have managed to extract the Lion and Mountain Lion "InstallESD" but the other (Tiger, Leopard & Snow Leopard) don't appear to have the "InstallESD" anywhere.... Do these exist anywhere as .app?
Help would be greatly appreciated.
Update (03/08/24)
Updated to Monterey 12.7.4 Now.
I fresh downloaded El Capitan.dmg and will 'try' to install this as a .app extension probably using a MBP 2012 as Monterey at the moment won't allow it.... I love apples OS but the company....
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Mmm… You maybe doing a bit much for one drive here. I like the KISS Philosophy and as simple as possible so I don’t screw up! With that a have a collection of 32GB thumb drives each one is setup with the OS-X Tiger/Leopard OS’s on independent drives (when the need arises) as well as the different macOSs I use day today. It also makes maintaining the easier as Apple throws Updates once and awhile.
So I first format the drives to GUID and a journaled partition (HFS+) then copy the installer on its own drive which I then convert with Terminal as outlined here Create a bootable installer for macOS on each installer. The issue you have is the drives name and the given folder or partition the file is sitting in can get messy if you try doing this on one drive, besides the space issues of not only all of the installers but enough free space to even run.
这个答案有帮助吗?
得分 0
6条评论:
I have got it down to 50-100mb over for each installer, all working fine, It is only Monterey on-wards that have updated installers occasionally... The remaining space has a Windows 11 to go partition, and all the "updates for the OS's that need doing after installation. plus some software. My question was how to get the 10.4 to 10.8 installers into .app installers, IF at all possible?
完成的
@livfe - Guess that wasn’t clear in your Q.
As far as the unused space the 32GB thumb drive as beyond the installer. It’s needed! Here it’s where the installer de-compacts the components for your system. While you could use a smaller drive every time you use it it wears the flash cells as the installer will reuse the space over and over again as it runs. So a few times no big deal, but do you want to bet the cell killer god? As one day when you need it it won’t work. I’ve used 8GB, 16GB and have found the 32GB are the most dependable for this task. Remember I’m a fixer who often uses these. If your like me then it’s a good investment for a few dollars. I can get a good set of five for less than $20 USD.
OK, did you slide down to the bottom of this Apple T/N How to download and install macOS I haven’t needed to build a new drive is so many years! I think I just made it as a bootable drive with its own install. Don’t get lost in the files extension .DMG will run natively.
完成的
@danj Yes I know you guys a far far more experienced than me, but the new drive is of course formatted and empty of an installer, so how would I get it to install from a .dmg file with no O/S installed to open it? Or have I missed something? I have also made another EL Cap installer on a 32gb USB, downloaded from the app store as a .dmg, run it, it made a .app in my applications, when I do the terminal commands I am now getting - Erasing Disk: 0%... 10%... 20%... 30%...100%...
Copying installer files to disk...
The copy of the installer app failed.
完成的
@livfe - OK, that’s different! It’s been years so bear with me! Do you have an option to point to a drive in the process? Again I set one up way back and I just don’t remember how I did it.
完成的
@danj Yes at one attempt it pointed to the ADATA SSD to install on, took ages, then get the error cannot install.... Trying with a Samsung 256 HDD soon.... failing that, would installing on another MBP 2012 then transferring the HDD back to the 2008 work or will I get the dreaded ROM or EFI thing all over again? I seriously want to get shot of all these older than 2012 models ASAP.
完成的
显示更多的1条评论
添加一条评论
Any OS from MacOS X Snow Leopard and newer should run fine. But, Mac OS X Tiger needs a PowerPC to run. It can’t even run on an Intel-Based Mac
这个答案有帮助吗?
得分 0
3条评论:
Yes aware of this, I just would like to know how to get the .app installer (Or the way to make these listed below onto a USB to install with)
OSX 10.4 Tiger DVD.iso (Not so important)
完成的
FYI - there are two builds of Tiger one for PowerPC and another for Intel systems like 15” MacBook Pro 1.67GHz Core Duo and OS X 10.4.5 Tiger Intel Installer DVD (Retail)
Heres the Snow Leopard 10.6 Snow Leopard install there is no need for Leopard 10.5 . And most systems support Lion 10.7.
完成的
OK great, I am getting them now.... I got the select language option now on Yosemite ..... which of course failed (Downloaded from apple) corrupted OS.... yay
Then next attempt, got the progress bar, then a bunch of black writing similar to a terminal command behavior and it auto shut down.... making a 32gb USB of EL Capitan now trying this.....
we should be in here Installing El Capitan on a stubborn 2008 MacBook in 2024
完成的
添加一条评论
添加你的答案
livfe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 67
