跳转到主内容
Repair and disassembly information for the Nokia G22 Android smartphone, first released in March 2023, built by HMD Global. Identified by model numbers TA-1516 or TA-1528.
18 个问题 查看全部
Where is the antenna
Where is the antenna?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
The antenna seems to be located at the bottom of the device. I believe it is integrated into the charging port PCB. Steps 21-24 in this guide seem to suggest that this is the case, but I am not an expert.
这个答案有帮助吗?
得分 0
1条评论:
Both bottom and top.
完成的
添加一条评论
Modern phones will have at least 4-6 antennas, most or all of them are used for cellular reception. You can't ask "where" without defining "what" antenna you are asking for.
They are usually spread along the top and bottom rim of the phone.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
F S 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 21
