跳转到主内容
加入维修社区 - 创建账户
eMac 是一款基于 G4 处理器的多合一 Mac,专为教育市场设计,于 2002 年 4 月发布。它是最后一款使用 CRT 显示器的 Mac,并以低廉的价格向学校及其他机构出售。
eMac not booting
My eMac stopped booting yesterday and when I try holding cmd+s at start-up fsck -fy says the volume appears to be ok. When I boot with sh /etc/rc, It goes until it gets stuck on 'SystemStarter[67] : Waiting for Apache web server'.
I don't know what this means, can I fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
10个答案
已选择的解决方案
One fix is a complete wipe and reinstall of OS - try an archive and install first.
Good Luck,
N
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Did you make any changes yesterday?
Try unplugging the network cable and safe (shift) booting. You may have to wait 10 minutes it takes longer to safe boot.
What happens?
这个答案有帮助吗?
得分 2
添加一条评论
IIRC SystemStarter[67] is an error code for local host. Have you run permissions and repair for your eMac?
这个答案有帮助吗?
得分 2
添加一条评论
If you are running OS X, try booting in Safe Mode (hold down shift at boot, until the spinning gear starts). Login to an admin account and turn of web sharing in System Preferences. Reboot normally and see if this resolves the issue.
这个答案有帮助吗?
得分 2
添加一条评论
I think the most likely culprits are a failing hard drive, or the bad capacitors problem that struck the first models of G5 iMac and the G4 eMacs.
First the hard drive. If it's the stock drive, it's a prime candidate for failure (most drives last 3-5 years; think of them as consumables, like light bulbs.) Unfortunately the SMART status used by Disk Utility is next to worthless for the most common failure I see, bad blocks (sectors). If you go to versiontracker.com and download SMART Utility, it will let you launch a few times as a demo. SMART Utility reads the SMART attributes of a drive directly and will tell you if your drive is suffering from a failure or imminent hardware failure. Of course, you'll need to boot to an external drive for this. SMART attributes can only be read on an internal drive, so putting your emac in Firewire Target Mode and connecting it to another Mac will not work in this case.
Second, the caps. Your symptom is actually more indicative of the hard drive problem, but if you get your computer booted and it freezes, shuts off, or has video artifacts like lines across the screen, then it could be the caps. If you're comfy taking it apart (no mean feat with an eMac, the bitty power cable is a bear to plug back in) you can examine your caps for bulging and leaking.
这个答案有帮助吗?
得分 2
添加一条评论
Did you try resetting the PRAM? Hold down APPLE OPTION P R when you start up, let it chime through a couple times, not just once... see if it resets the settings and lets you boot naturally.
这个答案有帮助吗?
得分 1
添加一条评论
Will it boot from an external dive with a good OS on it? If so, sounds like it is time to do an archive and install...
这个答案有帮助吗?
得分 1
添加一条评论
If you can boot from an external drive with a good OS run the disk utility. With the disk utility you can check/repair permissions and run disk repair. (files not mechanical). If no joy I think David is correct--time to reinstall your OS. Ralph
这个答案有帮助吗?
得分 1
添加一条评论
Hold down the option key when you reboot with the external HD plugged in, and it'll show you the drives and just select your external. Simple and easy.
这个答案有帮助吗?
得分 1
添加一条评论
I had the same problem and replaced all the capacitors that had burst. Took some time, but was fun and gave my daughter a free eMac.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
QEII Student IT 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 33
总计 8,065
