跳转到主内容
型号A1989,EMC 3358.更新了现有设计、处理器选项并且更换新的键盘材质.有银色和深空灰色可供选择.于2019年5月发布.
Activity Monitor crashes when selecting the Energy tab
Activity Monitor is consistently crashing immediately after selecting the Energy tab. I performed a clean OS installation and it still happens. I've got macOS Sonoma installed and recently had a battery replacement. This seems to have been a common OS bug on some previous OS's, so hoping it's just somehow software related (but not sure why a clean OS install wouldn't resolve that). Note that I've already tried deleting the com.apple.AcitivityMonitor plist file in ~/Library/Preferences but it didn't change anything.
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Let’s double check that replacement battery, install this Gem of an App CoconutBattery let’s see what it reports back post a snapshot of the apps main window here so we can see it too.
这个答案有帮助吗?
得分 0
4条评论:
Thanks Dan, added the coconutBattery results to the original question.
完成的
@zpl - mmm… something’s off here! Your system was manufactured in 2019/20 time frame, now looking at the battery we see it’s microcode has the battery dated back to 2015! So it’s possible Activity Monitor is crashing because we have a time warp! It’s reasonable to have a newer battery than the system, just not the other way around!
完成的
Interesting! I'll try swapping the battery with another to see if it still happens and let you know. Thanks!
完成的
@zpl - Make sure you do a hard SMC reset. Basically, after you pull the battery press and hold the power button to fully discharge the logic board. Just to be sure this batteries setting is not cached in SMC.
完成的
添加一条评论
添加你的答案
Zach 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 1,085
