跳转到主内容
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
87 个问题 查看全部
anyone know what it is for? for ipad air 2 cellular?
ANYONE KNOW WHAT IT IS FOR? FOR IPAD AIR 2 CELLULAR?ANYONE KNOW WHAT IT IS FOR? FOR IPAD AIR 2 CELLULAR?
I fixed ipad air 2 lcd screen
Accidentally I broke the antenna things
you can see the pictures
luckily still wifi and cellular are working thank god
I'm very curios what is this antenna for?
plz let me know thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I'm not 100% sure but those do not seem to be antennas. I very well may be wrong, but that looks like EM shielding made to protect the logic board from interference.
这个答案有帮助吗?
得分 0
2条评论:
Thanks for replying if u go wire things all the way there is antenna things at corner link together can u see? It looks same as ipad 5 and 6
完成的
You are right. Upon closer inspection I have realized what you mean.
The damaged IPEX cable can be replaced for cheap if you know how to solder, but the EMI resistance will be reduced and you will probably suffer more interference. If that bothers you, you can probably source a replacement from an online store or a broken donor iPad.
I am not sure what the broken antenna might do, but I believe it is responsible for 4G LTE MIMO (Multiple In, Multiple Out) for higher speeds. It is not vital for basic functioning, but it may significantly damage your network speeds.
完成的
添加一条评论
添加你的答案
Kyuho Lee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 34
