My Asus zenbook duo is not turning on
it turns on randomly after several clicks sometimes after few days it turns on. I suspect the issue is with the power key. To turn on ASUS zenbook duo the only way is power button, there are no other options(may be cmos battery removal would work)
If it’s power key can someone walk through the process of changing the power key or any other alternative.
Right now my laptop is turned off, it is not turning on.🥹
4条评论
This is a common problem I have also faced.
First try hold the power button for 5 seconds.
It might just give a blank screen with the screen pad on with full brightness(and if you had put the laptop at full speed mode the fans will be screaming (totallynormal) )
Press the power button for 5 extra seconds to fully turn it off
After this press and hold the power button for 10 seconds
By now your pro duo will turn on with the logo being the first thing it displays
It might take 1 minute for it to reach the lock screen which is okay.
And by now your laptop is now OK
Hope this helps
由 NURDIN ADAN 完成的
My one would just randomly switch off / restart if you opened the camera or switch the orientation, or if you tried using the Asus app
由 Yusuf Vali 完成的
EC reset will cycle your hardware , You need to do is turn off your Device remove power adapter and all external devices then press and hold the power button for 40 seconds , after that you need to wait at least 30 seconds before you turn on your Device again
I just receive this message from asus support and seems that is working. try it and tell me your feedback
由 Gabriel 完成的
did you find the solution?
由 Gabriel 完成的
