跳转到主内容
The De'Longhi EC155 is a Pump Espresso and Cappuccino maker.
25 个问题 查看全部
Why does my espresso machine make electric fuse off whenever I plug in
Today I tried to plug in my espresso machine but it made the electricity fuse off. I tried the same with other wall outlets, the result was same. What is the reason and what can I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @zigo95153
Do you have a DMM (digital multimeter)?
If not you will need one to find out why there's a short circuit in the power supply path of the coffee maker that is causing the fuse to blow as soon as you plug in the machine.
It could be a faulty power cord, faulty on/off switch or a wiring or component fault in the machine.
Here's some information that may help.
The ifixit De'Longhi EC155 guide that shows how to disassemble the coffee maker and this link that has a wiring diagram (scroll to the bottom of the page) so you can check where the problem may be.
If you don't know how to test using a DMM or to read a wiring diagram, then perhaps you need to contact a professional appliance repair service.
Note: You can use the Ohmmeter function of the DMM to safely test the circuit without having any power connected to the coffee maker.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Zigo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 19
总计 50
