跳转到主内容
Pages for the HP Pavillion e-series of 15-inch laptops, with either an 11th-gen Intel processor (15-eg) or AMD Ryzen 5 (15-eh) configuration. Released in 2022.
15 个问题 查看全部
How many internal memory slots are there? 15-ec2097nq
I want to upgrade my memory in my HP 15-ec2097nq to have a higher capacity m2 ssd. And probably an hdd for bulk files (photos, videos, large files, etc.). How many m2 /sata slots are there? And what are the speed limitations. Thank you in advance,.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @redill
The laptop supports up to a maximum of 32GB DDR4-3200 (PC4-25600) sodimm memory over 2 slots i.e. 2 x 16GB modules.
There is one M.2 PCIe 4.0 socket which takes an M.2 2280 NVMe SSD (up to 2TB) and you can also replace the existing sata HDD with a 2.5" 7mm sata SSD as well (up to 4TB). If you decide to upgrade the HDD to an SSD ensure that the SSD comes with a 9.5mm spacer, which is placed under the SSD so that it raises it to the correct height to align with the sata connector on the board.
Here's the maintenance and service guide for the laptop series that may help.
这个答案有帮助吗?
得分 1
1条评论:
Thank you, really appreciate that.
完成的
添加一条评论
添加你的答案
Redill 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 71
