跳转到主内容
The Lenovo IdeaPad S145-14IWL is a lightweight and compact laptop built for entry-level laptop users. The IdeaPad is affordable and robust, amazing for office work on the go.
What form factor is the SSD in this laptop?
I am looking to upgrade the ssd in this laptop and I would like to know what size M.2 drive it has. Is it a 2230 or a 2280 for example?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @timothyhoyles
The form factor is M2.2280.
Here's the hardware maintenance manual for the model.
Go to p.45 to view the procedure to remove/replace the M.2 SSD.
If you wanted to and if you haven't already done so you could also replace the HDD with a 2.5" 7mm sata SSD (up to 4TB). Ensure that you get one that comes with a 9.5mm spacer that is placed beneath the drive so that it aligns correctly with the sata connector on the board
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
timothyhoyles 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 129
