跳转到主内容
适用于 HP EliteBook 845 G8 的维修指南、拆解说明和故障排除信息。这款基于 AMD 平台的商务笔记本由惠普于 2020 年 12 月发布,型号为 1W3K7AV。
Can we have a general cleaning guide?
I just visited India. There is SO much dust there like I can't even describe it. I noticed more overheating so I assume it's dust filled into fans and stuff. Even the screen is icky. I was hoping for a cleaning guide (ex; fans, screen, between the bezels)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I guess....the answer is not necessary for being detailed. Anyone can do it.
All you need is a strong vacuum that can spin the fan. As for the bezel you, use it with great caution and avoid touching the screen.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @kalyabhatt
Here's the maintenance and service guide taken from this support webpage for the laptop.
It details the necessary steps to completely disassemble the laptop if that's what you want to do.
这个答案有帮助吗?
得分 2
1条评论:
Generally the parts that need maintenance are the fans, which can collect dust (plus anywhere else where dust has entered the laptop), and the thermal paste, which is on top of the CPU and under the heat sink.
So, basically use the pre-existing OEM guides on iFixit for the following:
* fan: HP EliteBook 845 G8 Fan Replacement
* and heat sink: HP EliteBook 845 G8 Heat Sink Replacement
If you've watched Andy's dust cleaning videos from the Salem Techspert YouTube channel, then you've already have a good idea on how to clean dust from this laptop.
完成的
添加一条评论
添加你的答案
Kalya Bhatt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 202
