跳转到主内容
加入维修社区 - 创建账户
型号A1367,闪存容量:8、16、32及64GB
How replace home button can't push-button?
My home button stop working the problem is that i cant push him.
His flexibility disappear and i can't push him.
what the part's i need i see that 2 parts sexist one is external rubber part and a small dual cable.
What part i need and where the cable location?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Be sure you want to undertake this adventure before you start.
tools you will need.
heat gun, utility knife, very small philips head screwdriver
the flex cable is more than likely the problem if the flexibility is gone. you can buy them online for about 5$ but if your going to go to the trouble you should just replace everything, flex cable and button. total cost 15$ because you need to get new tape/glue strips to hold the screen down.
there is a repair guide on here for you to follow
iPod Touch 4th Generation Home Button Ribbon Cable Replacement
the cable is underneath the mid plate
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Evgeny 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 5,358
