跳转到主内容
第五代 iPad Air 于 2022 年 3 月 8 日发布。它配备了 M1 芯片和 5G 网络连接。
18 个问题 查看全部
Are these two dark spots normal when viewing from one side?
When I view my top edge from the bottom side, I see these 2 small dark spots (1cm each). Not seeing them with viewing the display from above or normal usage without paying too much attention and dark images are fine.
Is this normal? Or it's a hardware issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Are you seeing them within a clean white space? It’s likely the graphic you have is creating the distortion.
这个答案有帮助吗?
得分 0
2条评论:
Yes, I still see them if I look from bottom.
完成的
@alireza83547 - There’s little you can do to alter this slight distortion in the display. I personally would live with it. If it really bothers you then you have to replace the display panel which I think is going a bit far.
完成的
添加一条评论
添加你的答案
Alireza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 24
