跳转到主内容
任天堂于 2021 年发布的 Switch OLED 机型的维修和拆卸指南。
Problem with oled screen
So recently i decided to swap out the back and bottom shell on my oled switch and thought i did everything correctly only to discover that it would not turn on, or so was my original thoughts. I remembered i had some issues with one of the ribbon cables, which later i discovered to be the oled screen one. So when i reopened the console, i made absolutely sure that all ribbon cables and cables in general were properly connected.
I still could not see the screen turn on to know the console was booting up until i decided to try to turn volume up and was able to hear noises from moving the joy cons around and verified that i got output when in docked mode.
so it seems the screen is not wanting to work, but i could not notice anything wrong with the ribbon cable. Is there anything i could do to try to figure out why the screen wont function or do i have to just bite the bullet and replace the oled screen?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
i took it apart again and discovered something in the oled connector port, likely the scratched off piece of copper i discovered on the ribbon cable, blew it out with compressed air and put it back together and now the screen is working properly again.
这个答案有帮助吗?
得分 1
1条评论:
Nice find, Thomas! Glad to hear you got your Switch working again, and appreciate you coming back to let us know what you found. You never know but that it may help someone else down the road.
完成的
添加一条评论
添加你的答案
Thomas Gantt 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 58
总计 984
