跳转到主内容
How to fix my PowerBook g4 that takes 3 times to power up right
I was wondering how to fix my PowerBook that takes three times to get it started but once it’s get to the loading bar the screen goes black but power is still on
I think it could be the heatsink it self because at first it was the RAM I cleaned it with Isopropyl alcohol to get any dirt and dust of the RAM port but that didn’t do anything. Or it could be the hard drive deading but I don’t think it would cause that issue.
I feel like the computer wants to work but just trying to figure out what is causing the issues to take 3 times to push the power button to get it to work properly.
When I push the power button for the 1st time the light comes but the sound doesn’t and screen stays black. But when pushing it the 2nd time it the light comes on but the fans will sometimes start to rev up or the sound will play but the screen doesn’t show anything.
On the 3rd time it will power on light and sound will work and screen will turn on but once it get to the loading bar it will go black again but the computer will still run
Also when it does go past the loading bar the screen stays on but then goes black without having the fans ramping up.
I redid the thermal paste but still nothing, the only thing I haven’t done was switch out the hard drive.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This PowerBooks where way ahead on what the technology could offer from a longevity stand point.
The displays used CCFLs (fluorescent lights) which need enough voltage to create a Mercury plasma. The capacitors & inductors often broke down and the CCFL tubes often leaked. If you plug in an external display to your PowerBook and that worked then you know one way or another.
The other killer is the Metal hydride batteries they don’t hold up limited cycles and the chemistry breaks down.
And as you noted the HDDs are sensitive.
There are a number of capacitors on the logic board that may need replacing and the power switch may need replacement too.
这个答案有帮助吗?
得分 0
6条评论:
The screen comes on but it flicker then it turns off. Before finishing to go to the loading bar.
完成的
@nickwood16080 - Plug in an external display what does it show?
完成的
No it doesn’t ever time it getting to the loading bar the screen and the external display don’t show anything.
完成的
Just stays black
完成的
I just got another logic board that I replace and I installed right but the fans are spinning but no screen or boot chime is working. What could cause the issue for that?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Nick Wood 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 89
