跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1990,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
Keyboard doesn't work after replacing it.
I have an A1990 Model Macbook that I bought second hand and the keyboard stopped working after replacing my battery. So I investigated the issue and found corrosion where the keyboard ribbon and keyboard connect.
I replaced both the keyboard and the keyboard ribbon cable.
The keyboard is still not working, no backlight, and non-responsive. I don't understand why it is no longer working since everything for the keyboard is new.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Does a USB keyboard work (via a USB-A to USB-C adapter)?
这个答案有帮助吗?
得分 0
4条评论:
Yeah I am able to use a USB keyboard to login.
完成的
@razitomeya - So tat helps in limiting where in the logic board you’ll need to investigate is damaged. Are you up to the challenge? You’ll need to grab the schematics and board views for your system, have a good magnifier, narrow tipped soldering and a steady hand!
完成的
Where can I get schematics? I have done low skill soldering like fixing my xbox controller, but nothing like this.
I would love to narrow it down.
完成的
@razitomeya - Google the boards number in your case 820-01041you should be able to find them.
完成的
添加一条评论
添加你的答案
Razitomeya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 154
