跳转到主内容
任天堂 3DS 的升级版。它拥有更大的屏幕、更长的电池续航时间、更高的像素密度和更好的设计。
Why won't any of my games work
I just bought a 3ds from Japan, it has been region unlocked but none of the games I have work in it. the pins aren't dirty or anything, but when I load a game it just says 'DS card can't be recognised. Please end the game and start again' or the screen just goes completely black and I have to turn it off and on again.
Ive tried googling but I can't find anything really related to this and I not sure what to do
does anyone know any way to fix this or have I just lost a load of money, I could send it back and get a refund but id still be losing money cause of the import tax :'(
can anyone help?
Update (02/20/24)
@rebtech it comes up with this
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
53条评论
Booted from CTRNAND
Are you missing your sd card?
完成的
@rebtech I don’t know anything about this sorta stuff, I bought it like this and it has no sd card or anything
I have ordered a as card for it though
完成的
Oh yeah, that's not good. You need the sd card. Booting Luma from CTRNAND is only for emergency purposes in case your sd card dies or the like. Under normal circumstances Luma runs from the sd card. Because you don't have the sd card you are missing the Luma and the god mode 9 files. Not to mention you have no place to install title updates or seeds. I'm guessing this is your issue. You got sold an "incomplete" hacked 3ds, incomplete because the seller with held the sd card. :(
完成的
@rebtech am I not able to put the same files on a new sd card or would it not work?
完成的
Yes that will work. Just follow the hacking guide. From this point:
https://3ds.hacks.guide/restoring-updati...
Then afterwards do this for god mode9:
https://3ds.hacks.guide/godmode9-usage
Don't use sd cards larger than 128gb, make sure to format it to fat32. You'll need to use a different tool to format sd cards larger than 32gb windows wont do it natively.
完成的
显示更多的48条评论
添加一条评论
1个答案
已选择的解决方案
The only way games could be region unlocked is if it's been jailbroken. The question is which style of jailbreak was used and how long ago was it done. This will help determine what to check and how to proceed. Figure this out first.
With the 3ds off press and hold select, then press power. What happens?
Have a read here.
Particularly
https://3ds.hacks.guide/checking-for-cfw
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Acacia Scurr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 535
