跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
BSOD on new build
BUILD:
i5 13600k CPU 13th Gen
Asus ROG STRIX B760-I GAMING WIFI
MSI MPG B760I Edge WiFi Gaming Motherboard
Corsair Vengeance DDR5 32GB 5600MHZ CL36 RAM
Lexar 32GB DDR5 RAM 6400MT
Onboard video
NVIDIA GTX 1050 Ti
M.2 SSD
ISSUE:
These BSOD error almost always point to driver issues but the BSOD error occur during Windows installation (before any drivers being installed). The few times I get passed the installation process it crashes during Windows setup process.
Things I've done:
Upgraded the BIOS on both motherboards
Tried different RAM (listed above)
Tried another SSD (new)
Tried with or without graphics card
Tried another power supply
Tried another motherboard (Listed above, using same processor)
Tried installing WINDOWS 8,10, 11 (same results)
Could it be the CPU? I ran the INTEL diagnostic tool and it passed. Incompatible RAM with CPU or MOBO? I'm lost here, any help would be greatly appreciated.
BSOD ERRORS:
CRITICAL_PROCESS_DIED
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
IRQL_NOT_LESS_OR_EQUAL
PAGE_FAULT_IN_NONPAGED_AREA
SYSTEM_SERVICE_EXCEPTION
NTFS_FILE_SYSTEM
ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY
KMODE_EXCEPTION_NOT_HANDLED
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @cascara,
Can you get into BIOS and navigate through the menus OK without crashing?
What are the wattages of the PSUs that you tried?
Try downloading and running this free program and check if it works OK. It's not that I think that the ram is the problem but this is a standalone program that doesn't rely on Windows to be loaded so that it can run.
Also try running a "live' version of any Linux OS, from a USB drive and see how that goes. You don't have to install it on the SSD just trial it from the USB
Just trying to eliminate things.
完成的
添加一条评论
1个答案
Hello! It's like you have a ram issue, Try to use ram from the list of manufacturer,for your Asus is here
https://rog.asus.com/motherboards/rog-st...
also it's posible to have a defective ram stick, if you have a set of 2 try one every time.
One more solution is to make a bootable usb from here to check the ram for errors
https://www.memtest86.com/
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Luis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 135
