跳转到主内容
Released around 2010, the Dell Inspiron 15R N5010 is a 15-inch laptop with an Intel processor and dedicated ATI Radeon graphics card.
CPU upgrade possible? (i5 460M to i7 720QM)
I have a Dell Inspiron N5010 with an i5-460M CPU. I want to try and upgrade it to an i7-720QM, however the latter has a TDP of 45W while the former has a TDP of 35W. Would this upgrade be possible?
If the stock power supply is not enough, I have a power supply with 135W lying around, so I can use that to charge the laptop.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I am not exactly too sure of the TDP issue, but considering how laptops are like, I would avoid going for CPUs that are above the TDP of your current CPU unless you are fully aware that said laptop is capable of supporting said CPU.
You will also need to consider the IGPU since the i7-720QM lacks said IGPU. However your laptop most likely has a dedicated issue so this shouldn't matter that much.
You should also consider thermals since these better processors can run hotter.
I would recommend going for the i7-640M or i7-620M as their TDP matches that of the i5-460M.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ibrahim Anser 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 334
