跳转到主内容
An affordable mid range laptop sold by Acer in mid 2015. This laptop comes with a Nvidia 940m graphics card, Intel i5-5200U CPU, and a 1080p display.
29 个问题 查看全部
Can I swap the LCDs of this laptop to a Acer V5 431?
Can i swap the LCDs of these two?? An Acer E14 and Acer v5 both has the same screen size but different connectors. The E14 has 30pin for it's LCD while V5 has 40 pin i was thinking if its okay if i also move the flex connector as well is it possible??.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @markangcos
You can't just interchange 30 pin LCD screens and 40 pin LCD screens that easily.
The panel's operating specifications e.g. LCD panel's operating voltage (Vcc) value, backlight enable voltage signal value, LED power requirements and LVDS cable wiring pinout connections were chosen as these will work with the motherboard that the panel was originally connected to.
If you wish to check what these are, search online for (insert make and model LCD panel¹) datasheet for both LCD panels, to hopefully find them.
If you do find them, then they will have the specifications for the panels so that you can compare if they are the same or not.
If their operating specifications aren't the same, then it won't work and if you try anyway you may end up damaging the LCD panel, the motherboard or both.
If it is only the wiring pinout connections that are different you may be able to adapt the cable so that LCD panel pinout matches the LVDS connector pinout on the motherobard that it is going to connect with.
¹ Usually the make and model number of the LCD panel can be found on the back of the panel itself somewhere.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mark Angcos 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 28
