跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
708 个问题 查看全部
There is no place to screw in screws for the right joycon sensor rail.
A car door got shut on the docked, right joycon of my nintendo switch ripping out the sensor rail with it. I've replaced the joycon, and am on to replacing the sensor rail, when I was screwing it in, I realize that there is nowhere to screw it into. Can I glue it in? What part do I need to replace to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I ran into the same situation when my granddaughter somehow managed to rip one of her joycon controllers off the Switch, leaving it in the same situation you're in, with nowhere to screw in the rail.
I looked at several different possible solutions initially, but finally ended up biting the bullet and replacing the midframe. The midframe is what the joycon rails screw into, so when they're broken out the pot metal the midframe is made of tends to come apart. Here's the guide I ended up writing as a result of that adventure.
Nintendo Switch Midframe Replacement - iFixit Repair Guide
The other repairs I considered included things like filling the broken metal with JB Weld epoxy then drilling and tapping new holes, buying longer screws with nuts to be mounted behind the original screw mount, or just epoxying the screws in permanently.
To be honest, there isn't really a good solution here; the one I picked means you have to completely gut the entire Switch and move every single component to a new midframe. However, the other choices just didn't strike me as much better in terms of being a long-term permanent solution that was going to stand up to my rather breakage-prone granddaughter.
That's what I ended up doing; if you decide on another solution I'd love to hear about it; take pictures and maybe make your own guide to that repair; I would sure love to have had a better choice available. Let us know how it all turns out!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lunearity 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 25
