跳转到主内容
蘋果2020年的主流型號iPhone,其發布於10月23日,搭載6.1吋OLED螢幕及12MP雙鏡頭模組。其有著5種顏色,為iPhone11的後繼產品。
170 个问题 查看全部
Face ID And True tone Disabled
Hi, so I got an iphone 12 from somebody that disconnected the front ear speaker because he said that the cable is broken and the problem is of course the face id because when I try to set it up it says "Face ID is not available, Try setting up Face ID later. And my question is theres a way if i connect the broken cable to the motherboard again will I regain the face id and the true tone function back ?(I know probably it is a stupid question but i am very curious because I have an iPhone x which has the same problem, but on the iPhone x I can t even tap on the "set up Face id" because it says something like "a problem has been detected with your true depth camera"....blah...blah).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hello, the person who disconnected the ear speaker probably did that because (I don’t now exactly) but I heard that if it’s broken the phone will bootloop but probably when he/she did that he/she probably broke the Face ID and true tone or if there is a new display installed the True Tone will also stop working. So if you reconnect the ear speaker the phone will probably bootloop again. You can try buying a new ear speaker but it won’t help the Face ID or True Tone. If the Face ID is broken it can’t just be repaired however if you are lucky he/she also disconnected the Face ID sensor, if you reconnect it it should work again
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rios 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 58
