跳转到主内容
Lid not closing all the way
Hi,
About a week ago the lid started not being able to close all the way (it started with one side not touching and then both). I assumed it was a battery swelling problem because this has happened once before, so I removed the battery. But unlike my first battery problem, the lid still couldn't close even without the battery inside.
A couple days later the lid still can't close so I assumed it might be a hinge problem. Waited a week for tools to ship, then tested out the hinges. The hinges were tight, so I took out all the screws and the lid was finally able to close. I put the screws back in one by one, and it turns out that tightening any of the three screws on the right side too much caused the lid to rise.
I tightened them as much as I could without causing deformity, reassembled the laptop back together, everything looked good, and the lid closed properly. But when I opened it there was a small cracking sound (coming from where the right hinges were), and when I tried to close the lid it returned to the original problem. I repeated the same thing, fixing all the hinge screws again and the laptop easily closed. Right now it's staying closed just fine but I haven't tried opening it.
This seems like something's wrong with the screws but I'm not sure what to do. (I do wonder if waiting a week for tools allowed for even more warping to occur.) Does anyone have any advice or experience with this?
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Did the hinge look damaged
这个答案有帮助吗?
得分 0
添加一条评论
Can you explain a bit more here on what the lid is doing. Maybe posting a few pics might help.
From your description it’s hard to tell what needs fixing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nat 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 46
总计 118
