跳转到主内容
Released in October 2008, the Dell OptiPlex 760 SFF is the small form factor model in Dell's OptiPlex 760 lineup. It is relatively simple to open and repair.
4 个问题 查看全部
No video is the VGA damaged
so it was around 5 years ago I started using it again and now getting it out again then setting every thing up and screwing in my vga i get no video signal and some beeping like a ram error or video or morse is the morse - -- - -- -- -- - - - --
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @r4czygipoxlza4
Given that the "morse signal" you posted is the actual code it seems like a 2:1 error code.
This is a BIOS checksum error.
Since you haven't used it for approx 5 years (is this correct?) there's a fair chance that the non rechargeable coin cell RTC battery on the motherboard has become completely discharged and the BIOS has become corrupted, preventing a normal start.
Disconnect the power from the PC and then open it up and locate the coin cell battery on the motherboard
Remove it from the board and check its voltage. If it is <2.5V DC replace it. Usually they're a CR2032 type Lithium coin cell (check type number on battery) and are available everywhere. I suggest that you replace it anyway as these batteries only last for 4-6 years.
With the RTC battery removed, press and hold the PC power On button for 30 seconds and then release it.
Reinsert the RTC coin cell battery (+ve on top as marked on the battery) reassemble the PC, reconnect the power and turn it on and check if it now works OK.
If it works OK, there may be a message regarding the date and time being incorrect. This is normal as the BIOS has been reset back to its default condition. Once the date and time have been corrected the message won't appear the next time the PC is started. Also any user definable BIOS setting that were altered by you to suit whatever operating requirements you has, will have to be changed back again also.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 52
