Nintendo switch component identification
hello! I'm maintaining a Nintendo Switch and a diode that says N is bad. Can anyone tell me what diode this is?
It's a zener diode. Can't say for sure what the value it's supposed to be.
However....it looks suspiciously off its own pad and close to its neighbor there. Try flowing it fully over onto it's own pads, separate from the other component. Rule out a possible bridge between the two. After you rule out unwanted bridging, check the voltage coming into the diode and that'll give you a clue as to what value replacement you need to source. Good luck.
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 11
总计 140
