跳转到主内容
非苹果电脑键盘维修指南。
248 个问题 查看全部
Membrane keyboard CAPSLOCK is not functioning (HAMA Cyberboard)
Is a membrane keyboard repairable? Does it worth it? I like this keyboard of mine, I can live without CAPS but if it not that hard to repair, I would definitely give a chance before I would buy a new one.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Short Answer is, yes, they are repairable. You will need a multi-meter and a means of bridging the defects you find, conductive ink is a good choice. The problems you will face are opening the case without damaging it so you can put it back together when you're done, and locating the areas that need to be fixed. once you have it open all you need to do is perform continuity checks on all those silvery metal things , when you find a break in the circuit using the meter, dab a tiny bit of the conductive ink on the bad spot and keep checking when you've located and patched the bad spots let everything dry nicely then reassemble it. membrane keyboards fail because the circuit gets warm and fails - basically cracks in those silver puppies. if your keys are the sort that will fall out and scatter best take a photo first so if they do you can put them back where they belong. Whether that fits "not too hard" I don't know, but hey, consider it an adventure and don't stress out over it. If you succeed, be prepared to do it again as all those little membrane keyboards do this (and will again) Good Luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bohr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 37
