跳转到主内容
Pc Shut down after 1sec
When i plug my pc is automatically power on the after 1second it shutdown, if i press the power button nothing happens but it i unplug and replug the charger it startup and after 1 second it shut down again
I had The issue of the pc automatically powering on when i plug but before it start up>shut down>start up normally but it didn't really bother me
And i don't have a battery
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It's shutting down because the charger/power adapter you're using is not the OEM charger that it came with, and it's not providing the right amount of Watts/Volts in order to power it up fully so it shuts down immediately since there is no battery. Or it's the OEM charger and it's going bad or the laptop put itself in a low-charge state which then the adapter wont deliver the right amount of power and since there is no battery it immediately shuts off. It's best if you find a replacement battery that way it has the ability to charge and work the way it's meant to.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ilias 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 175
