跳转到主内容
加入维修社区 - 创建账户
苹果于2021年9月更新iPad mini,配备A15 Bionic处理器,8.3英寸屏幕,全新设计,侧边按键式触控ID,并且支持第二代Apple Pencil。
Does Mini 6 Touch ID lock button replacement need to be paired?
Hi, I have two iPad mini 6's and would like to swap the Touch ID button from the old one to the new one. They both work, but the new one is loose in its socket with a weird rattle. I remember when Touch ID first came out, the button was paired with the motherboard and only Apple had the equipment to re-pair a replacement button. Since that time, I feel like I've read that this is no longer the case, but I can't find any straight answers online that are more recent. I know I can phyiscally make the swap, but it's a lot of work if it just turns out to not work in the end. Does anyone have a current answer about that? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You felt wrong, it is always the case.
这个答案有帮助吗?
得分 1
2条评论:
Tom's answer is, as usual, terse but right on the money. All Apple products that feature Touch ID or Face ID have the components involved paired to the motherboard. There are no exceptions, so as you've observed, yes you can physically swap the Touch ID parts. The button function will continue to work but Touch ID will be disabled.
完成的
Thanks for the reply. Would've been even better without the snark.
完成的
添加一条评论
添加你的答案
Grant 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 56
总计 1,288
