跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
424 个问题 查看全部
Center battery screw broke?
Hello! I was replacing my Mac’s battery (Air 13” 2017) and all was well until I was screwing the new battery into place, and the center screw just broke? I’ve already ordered replacement screws but now I’m trying to figure out the best way to get the broken screw part out, especially since it’s so small (like, 1mm width).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It depends!
To be clear you where screwing in, so it bottomed out. If that is the case the screw is likely loose so using two sewing needles pressed lightly into the shaft at the edges sandwiched between two tongue depressors should allow you to spin it out. Take your time as it may take a few tries.
If the threads are jammed then you’ll need a left hand drill and a jewelers vise (drill) use a sharp small carbide point scribe tool as a punch to set the drill bit in the center of the screw.
这个答案有帮助吗?
得分 0
1条评论:
I actually have some sewing needles, I’ll try that!! Thank you so much.
完成的
添加一条评论
添加你的答案
niesg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 9
总计 29
