跳转到主内容
任天堂3DS XL 2015在市场上被称为新任天堂3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
380 个问题 查看全部
Console Powers On ( Blue Light ) but both Screens stay black
Hey Guys,
I bought a faulty New Nintendo 3DS XL where it said that the Blue Light turns on but the screens stay Black.
I received the console without an SD Card so i cant really tell if there is CFW or not.
I tried booting it while holding the Select Button and also while holding A+L+R+Up and that didnt workt either.
I inserted an SD Card and did the same thing again and that did nothing as well.
I added the Luma files onto a newly formated SD Card and tried booting both ways again and still nothing happened
I went ahead and opened up the 3DS and disconnected everything to the point where i arrived at the bottom screen but all the componets and cables look fine.
I tried booting it with the camare ribbon cable disconnected because i read online that that may be the cause but that didnt work either.
I have not dissambled the whole Console yet because I wanted to ask for Help before i go all the way.
Maybe someone had a similar problem and found a solution.
Thank you for all Answers in Advance
Jason
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
try unplugging the ribbon cable right at the first board when you take off the second plastic piece and plugging it in right back. it's the only similar problem i ever faced and it solved this way
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joker 1999 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 27
