跳转到主内容
加入维修社区 - 创建账户
The Nokia 3310, released in 2000, is known for being incredibly durable.
I don't know if charger don't work or travel adapter phone not charge
phone doesn't charge.... when I connect my charger to my adapter to charge phone nothing works ? I can't charge phone without adapter because the pins are different I'm starting to think maybe something wrong with the charger port or travel adapter
only have 2 bars left of power on my nokia :'(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Hi @aaronc63961,
Please confirm whether you have a Nokia 3310 or a Nokia 3310 3G as they have different charger connection type i.e. DC barrel plug versus micro USB connector?
What are the AC input voltage specifications for the charger you have now (printed on charger case) e.g. 100-240V AC, 240V AC etc?
What is the voltage supply value of the location that you are in now?
完成的
Hey thanks for fast reply I have the old Nokia 3310 the dc barrel one. Chargers input says 100-240v~ 50-60hz 150ma and output is 5.0v 550ma. the charger is type A (so us charger) i live in australia my travel adapter is 250v~ 10A and i tried multiple wall sockets to charge it and no charge still nothing
完成的
yes its like this one https://ae01.alicdn.com/kf/H27433e84294f...
also its very loose when i put it into any wall socket if i don't hold it it's loose and hangs
完成的
添加一条评论
1个答案
最有帮助的答案
@aaronc63961
Bear with me, I'm a bit slow on the uptake ;-)
You have something similar to this to connect a USA charger to an Aust. wall power outlet, is this correct?
If you have a DMM (digital multimeter) you could check if there's 5V DC on the charger's output plug.
Alternatively if you're in Aust, you could go to a local supplier (example only) and check if they have a suitable USB cable with the appropriate DC plug size (take the phone) and use that connected to any mobile phone charger (which allows for a removable USB cable) or connect it to a computer's USB port.
Note: make sure that the DC plug is inserted into the USB cable the correct way as it appears in the image that it is reversible as far as polarity goes. Get the store to check this first if you have to get one with a reversible plug connector.
这个答案有帮助吗?
得分 1
2条评论:
thank you so much for advice at the moment i don't have multi meter but i will try and get a usb to dc plug
完成的
@aaronc63961
I was updating my answer when you replied so check the note about the polarity if the DC plug is able to be inserted in a different way thereby reversing the polarity of the DC supply. If reversed it could damage the phone - in the image you can see the two pins on the plug and the two holes in the connector at the end of the USB cable. Usually they are designed to go either way allowing for a +ve or -ve DC supply which can be a problem if you put it in the wrong way.
Sometimes it is marked on the plug and the connector it plugs into which is +ve so you can line them up to match i.e. +ve to +ve
The phone requires a +ve DC supply.
完成的
添加一条评论
添加你的答案
Ajax 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 260
