跳转到主内容
Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
113 个问题 查看全部
Based on his thermal image, is this resistor blown?
So I’ve decided to learn component level repair, and just got this Seek thermal imaging camera.
I used it on this MacBook that doesn’t power on board 820-01598-06, and when it’s plugged in to power, this resistor is the only component that lights up red.
Based on this, would it be safe to say that tha resistor is blown? I’ve got a multimeter. Just not sure what setting to use and what reading is normal.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi @applerepairshop
Looking at your images, I am not very sure that the inductor is where the heat is coming from as they very rarely go bad. You can test it to see if it shows a high resistance. It should only be around 0.019 Ohms when you measure across it.
I am more inclined to say that the surrounding mosfets or caps have gone bad as they handle the main power rail coming in form the charger. I would also check if the rails on the other side of the board on U7000 as that may be where the heat is coming from. That chip is responsible for the power management.
This the that inductor you marked on the picture.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
applerepairshop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 23
