跳转到主内容
加入维修社区 - 创建账户
一款任天堂为 Switch 系统生产的无线、传统的视频游戏手柄。型号:HAC-013。
None of my triggers are working.
I have tested all the traces that connect to the trigger assembly and confirmed that they have connectivity. I have cleaned the flex cable multiple times. I have also ordered a replacement part and the same problem still resides. There are no other issues with the controller. Any ideas as to what could be wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I have had this happen with my Nintendo Switch Pro controllers before as well. The first step is to take the back plate of the controller off, open it up, and carefully lift the triggers and rubber pads up. If you see any debris, or corrosion, use some isopropyl alcohol on a q-tip to gently wipe it off of the contact. If this still doesn't work, you may need to get a new controller, unless you're willing to replace the internal board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jack 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 33
总计 797
