跳转到主内容
模具型号A1707。于2017年6月上市,这台MacBook Pro的特征为配有Kaby Lake处理器,可升级至2.9GHz、可动态超频至3.9GHz四核英特尔酷睿i7处理器。
327 个问题 查看全部
Best way to remove stripped screw in motherboard
Hi There
Recently I followed the guide for a replacement for my battery.
While replacing the battery everything worked out great steps where nicely written but I've ancounterd a problem.
When I put my motherboard back in I saw a cable that was still stuck underneath it. I didn't see it untill the end.
Now I try to undo everything but I can't get these stripped screws out. It is litterly impossibe. The screws lost there grip so easily. So now basicly I can't get my keyboard plugged-in. I know I shoud've double checked it.
In the picture below you can see which screws i'm talking about.
Has any of you any idea of how I could try to remove these screws so I can plug my cable in?
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
So you've put back in the battery at this point and now just need to fish out the cable which is stuck under the logic board.
Sounds like your driver is not a T3 Torx or is well worn! I would try to get a replacement bit and you might try a T5 bit to see if that works.
Ideally, you really should take the logic board out but these flex cables do have a bit of flex, the only down side is the connector here is quite large and won't roll up and out, unlike the older keyboards which had a ZIF ribbon design unlike this series.
Just the same get a small Allen wrench which you can try to fish out the cable be ever so gentle! You don't want to damage the cable or the connector. See it that saves your bacon. Good Luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ChristopheTriesToFix 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 31
