跳转到主内容
Whirlpool Gold Series Dishwashers can be identified by model number WDF750SAYM0, WDF750SAYM1, or WDF750SAYM2.
22 个问题 查看全部
Dishwasher fills stops next cycle after few seconds of spray
Model gu2455xtsb3, fills with water, moves to next cycle and starts to spray for few seconds and stops, control panel lights all go off. No flashing lights and does not drain until you hit Cancel/drain butto
Update (03/03/24)
Replac d control board and that resolved issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @kurtiskeling
Here's the tech sheet for the dishwasher.
Initially perform the Checking keypad operation procedure (see centre section, bottom of p.2) just to check if the keypad is OK or not.
If it is then run the Service diagnostic cycle tests as described by the sheet (see left side, bottom of p.1) to check if it shows what's wrong.
If you do find the problem and it is a part that needs replacing, here's a parts list that may be useful.
Scroll through the list to locate the wanted part, to find the manufacturer's part number that is listed with it. Then search online for the part number only to find suppliers that suit you best.
这个答案有帮助吗?
得分 1
5条评论:
Ran service test by pressing Heated dry, normal, heated dry, normal. Display showed d3 and Rinse Only lit up, then switched display to 07 with Normal light on ran a few seconds and then the whole thing just went dark and powered off. Just like when we try and run a regular wash cycle.
完成的
@kurtiskeling
Do all the LEDs turn on when first starting the diagnostics?
Does it start to fill with water?
If you haven't already done so disconnect the power to the dishwasher for ~10 minutes, reconnect and check what happens
完成的
All LEDs come on at start of Diagnostic, just rechecked continuity on both door switch sensors and they tsted fine. First time DW stops tub about quarter full and water has not reached float switch, so I restarted diags and second stop water is touching float switch but not activated, meaning i am able to lift float and then hear it click, retart diags again w/o draining and stops butfloat switch is now activated. Restart again and it runs through all od diagnostic.
完成的
@jayeff unplugged DW few times during continuty testing.
完成的
@kurtiskeling
Seems as though the float switch may be faulty - sticking?
完成的
添加一条评论
添加你的答案
Kurtis Keling 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 62
