跳转到主内容
Lens cover won’t stay in place
My Eufy video doorbell is c 3 yrs old.
I recently noticed there was water under the glass disc which covers the camera lens and brought the device indoors to try and dry it out.
The lens cover subsequently fell off and will not stay back in place.
On inspection, it seems the “bezel” which retains this glass disc, and keeps things waterproof, has degraded.
The company can’t give me any advice re repair and just tell me to buy a new unit.
I feel this is wasteful - and surely the design life of this sort of tech should be longer than 3 years!
Can anyone suggest a safe way I could secure the glass cover back in position?
The only thing I’ve though of is tracing a bit of glue round the perimeter with a cocktail stick and then pushing the lens cover back in position.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I had exactly the same problem and added some kit (TEC7) between the protective plastic circle (it is not really a lens) and the enclosure. Make sure the lens is dry and don't push to hard when closing it. I used 2K glue before that, but that didn't keep it watertight. The TEC7 kit (some kind of silicone kit) worked better.
But then the microphone died after a while and I can't get that repaired...
这个答案有帮助吗?
得分 1
添加一条评论
Mon disque s'est détaché, j'ai mis de la glu en gel, mais il y a un nuage sur la lentille comme si la glu avait déposé un film ???
Je vais essayer de démonter par l'arrière et regarder si je sais essuyer avec un coton-tige.
Si je dois remplacer le matériel, j'achèterai certainement une sonnette Tapo de TP Link, j'ai plusieurs camera c310 et c320 qui sont à la pluie battante depuis 2 ans sans soucis. Ma lentille s'est juste détachée 1 mois après la fin de la garantie.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Betty Mack 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 72
总计 1,158
