跳转到主内容
谷歌第三代 Pixel,是谷歌首款"刘海屏"手机。配备了一块 6.3英寸 QHD+ OLED 显示屏,内存有64 和 128 GB可选。三款配色分别是(差不多)白,(就那么)黑,(不算太)粉。
Screen unresponsive after battery replacement.
After replacing my battery yesterday, the screen worked fine for 1–2 hours. Then the touch functionality stopped working in the top third of the screen. Within 30 minutes, there was no touch functionality except for the bottom 5 mm of the screen. I left it overnight, and now the screen flashed a few colors and won't turn on. I assume the phone is on since it vibrates when I hold the power button. After opening it up again, I checked the connectors for display, battery, buttons and coil, which were correctly seated. The display is still black.
Is the only option a replacement screen, or is there something else I can try before committing to that option (200€).
EDIT:
For some reason, the screen now flashes on dimly and the shuts off quickly while a white line appears in the top third of the screen when I press the lock button.
EDIT 2:
After turning off and on again, the display turned on for a split second showing the boot process, but faded to black right away. I can make out a faint Outline of the google logo afterwards, but nothing after. I'm starting to suspect that the backlight isn't working...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
It seems that IPA seeped into the display somewhere while replacing the battery, causing these issues. After letting it sit a while (sometimes warming it up), the display works again. Touch is still a bit spotty and it flickers sometimes, but I hope this will resolve itself once all the IPA evaporates.
这个答案有帮助吗?
得分 0
添加一条评论
Double check the screen connector
这个答案有帮助吗?
得分 0
2条评论:
Just did. Have opened the phone and unplugged then replugged the screen twice now, no change.
完成的
@jaundice then you'll need to replace the display.
完成的
添加一条评论
添加你的答案
Jaundice 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 25
总计 278
