跳转到主内容
After motherboard change, lcd is black. What can it be?
I changed the motherboard (The other one was not working) but after the change and all the components correctly connected (Except battery, im still waiting for the replacement to arrive) fan spins, but only shows a black screen, no apple logo, no backlight issue, only black screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
11条评论:
Do you hear the boot chime?
完成的
Unfortunately it doesn have speakers, so i cant hear if the boot chimes
完成的
@mitigations - Have you tried connecting an external display to the Mac?
完成的
It wont connect to external sources
完成的
@mitigations - Unfortunately this is tough. Since there is no way to test the Mac via external devices, there is no easy way to figure out what the problem exactly is.
So, either your display, or your Logic Board is broken.
完成的
显示更多的6条评论
添加一条评论
1个答案
Aim a flashlight thru the lids Apple logo, it should offer enough light to see a dim desktop and its icons. Does that work?
这个答案有帮助吗?
得分 0
1条评论:
I flashed a light in the apple logo, but still wont show any boot menu options or login screen
完成的
添加一条评论
添加你的答案
Mitigations 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 154
