跳转到主内容
The XV40 Camry was introduced at the 2006 North American International Auto Show alongside a hybrid version and went on sale in March 2006 for the 2007 model year.
23 个问题 查看全部
ac interior blower motor still on after engine turned off
Battery was dead so replaced the battery, but when I hooked the new battery up the interior fan went on and stayed on even after pulling the appropriate fuses. I disconnected the negative post on the battery so it wouldn’t run the battery down. What could cause this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Most likely a relay stuck. Or is it possible that you connected something to the new battery incorrectly?
这个答案有帮助吗?
得分 0
2条评论:
Battery was connected correctly. So is the relay part of the blower motor or somewhere else, and if part of the motor do I need to replace the whole motor?
完成的
The relay is usually separate and as far as a location you can Google search your exact make, model and question and that should bring up videos and other instructions.
完成的
添加一条评论
添加你的答案
Jay 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 47
