跳转到主内容
The third revision of the classic Xbox Wireless Controller was released in November 2020, bundled with the Xbox Series X and Series S. This controller is backwards compatible with previous Xbox One consoles, and PCs.
42 个问题 查看全部
Remove Existing Joystick Solder
I am trying to replace the joystick due to it sticking/stick drift; however, I cannot remove the existing solder. Does anyone have any tips or am I doing it wrong? I also believe I've burnt the circuit board but luckily this is a practice one.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @jayshiz
I would apply flux to the solder joints and use low melt solder to mix with the existing (probably lead free) solder. It will make it easier to reflow them with a heat gun or a soldering iron.
Once you managed to get it out, clean the holes with solder wick and you'll have no problem installing the new stick.
Hope it helps!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jay Shiz 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 98
总计 578
