跳转到主内容
The Bose QuietComfort 20i are in-ear headphones from Bose. Released in August of 2013. Model number: 362544-0010.
12 个问题 查看全部
Static noise when enabling NC, and is this a reset hole?
My Bose QC20 has developed a static noise when NC is enabled and they are not connected to a device. If I touch the connector tip the static noise disappears, when I stop touching it it comes back. I used to use this headphones for NC only but now I can't as they static noise is very annoying. I think it must be a grounding issue but What can I do?
I have searched online and found the answers about cleaning the earpieces and making sure the screen in the earpieces is in place and not pushed inside. I did all that but that didn't help.
On the other hand, I realised there is a little undocumented aperture near the cable in the control module. It's like a reset hole, although different. see images. I tried to find what's that for but I haven't found any manuals or images that include that aperture. what's that for?? I was suspecting/hopping it's a reset button?
I've tried to press with a small screw driver. Try to cross what appears contacts, hoping it's a reset button, but nothing has changed. I've only tried this with the NC disabled in case I damage something.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I can’t say for sure, but noise canceling requires a microphone to hear the background. Depending on the given headphones design it could be one or two mics. Often they are near the ear but not always.
I would try a short blast of canned air to see if that helps.
Otherwise, look at the cables are any of them damaged around the interfaces.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
martinako 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 59
